Head Unit Cutting Out
  • 4
307Bronco
15
Cheyenne
Having a real annoying issue. I recently installed a Pioneer DVH-885AVBT in my truck running the stock cardboard speakers. After about a week, the driver side speaker died and the headunit started experiencing the following:
- All speakers cut out. No sound in the vehicle
- The screen stays on, all other function seem to remain intact
- Can only recover sound if I change the radio station to the next station. If I am listening to app radio or my iPhone I have to change inputs.
This is becoming quite obnoxious. I could be wrong, but I would assume that if it was a bad ground or supply the issue would be across the entire spectrum of features or the entire unit would cut out. I would love any thoughts or ideas on how to remedy this.
Thanks!
Your gonna have to remove it and check your connections. It could be as simple as 2 wires together not crimped properly. It happens sometimes but it does sound like a wiring issue.
soldering the wires will help keep a connection better than crimps unless you get a really good crimp going
especially with smaller wires
Ended up having to replace the head unit. I think the original went bad or shorted. I will probably send it in to be refurbished. Replaced it with a DEH-80PRS so its really not a loss...... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
6
498
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
769
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
809
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
307Bronco
307Bronco
Cheyenne
307Bronco
