Rear batteries don't seem to be charging
  • 4
Airman21
Ohio
I have a 300amp alt and Duracell agm in the front with 2/0 going to the rear batteries (2 XS Power 3100). Noticed the volts on my Taramp 8000d was reading 11.7. Normally it reads low 14 until I am really pushing it then it drops down to low 13's. I started checking the amp before I would drive to work or home (1 hour each way). 11.7 at idle and when using the subs it would drop to 10.9. Next trip it started at 11.6. Seemed to drop .1 after each 1 hour drive with low volume. Front battery is totally charged so I know the alt is doing it's job and my electrical system is staying at 14.1 while cruising and 12.4 when idle so everything is good there. I checked my fuses everything is good. Is the 1 run of 2/0 not good enough? I would think it would be enough. Even with the subs turned off and a 1 hour drive the batteries didn't go up in voltage at all which makes me think maybe something with the wiring is the issue. Any ideas? I have the charger hooked up to the back batteries right now. Been pumping 40amps for 3 hours and still not fully charged yet.
Just start checking connections, like the rear battery ground to the car.
Yep I went out and checked connections. The positive on from the front battery to the rear was disconnected. Dang mechanics... lol.... everything is working as normal thanks...
Shocked that I was able to go 2 weeks on battery only for both amps. Those xs power are no joke.
check in line fuses.. 12.4 isn't very good at idle mine is 14.6 with no extra batts big 3 or big ga wire.. just let advance load test it..
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
733
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
892
Airman21
Airman21
Ohio
BOOMINGRANDPA
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
