head unit suggestions
  • 2
I need suggestions for an hu with the following:
-rca or high level out(rca is preferred). high-low converters are cheap, but hu's will distort when the high level, if it has one, is near full volume. I like to just yank the knob up to full, but with distrotion I'd have to set my amps at a higher gain and only turn the hu up part way.
-removable storage input. mp3's on a sd card, micro sd, usb drive,etc. also needs a good d-to-a converter.
-single din
-buttons to skip tracks, play/pause, volume...
thanks for any help
I would step up to at least the cde147. Has 3volt pre outs and other great features you will end up using...
I'll be using a line driver and crossover anyway. I'd prefer if it didn't have sub x-over and the line voltage doesn't matter. I'd honestly prefer a line voltage of 8v.
Favorite midbass I have ever used so far is the ML 1800.3. Close second is the yellow-cone polyglass mids from focal. I hate the focal for a 2...
21
3K
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
425
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
565
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
691
mrawesome
mrawesome
Raleigh, NC
mrawesome
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
