head unit suggestions
  • 2
I need suggestions for an hu with the following:
-rca or high level out(rca is preferred). high-low converters are cheap, but hu's will distort when the high level, if it has one, is near full volume. I like to just yank the knob up to full, but with distrotion I'd have to set my amps at a higher gain and only turn the hu up part way.
-removable storage input. mp3's on a sd card, micro sd, usb drive,etc. also needs a good d-to-a converter.
-single din
-buttons to skip tracks, play/pause, volume...
thanks for any help
I would step up to at least the cde147. Has 3volt pre outs and other great features you will end up using...
I'll be using a line driver and crossover anyway. I'd prefer if it didn't have sub x-over and the line voltage doesn't matter. I'd honestly prefer a line voltage of 8v.
Favorite midbass I have ever used so far is the ML 1800.3. Close second is the yellow-cone polyglass mids from focal. I hate the focal for a 2...
21
155
554
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
659
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
mrawesome
mrawesome
Raleigh, NC
mrawesome
audiobaun
    May 19, 2024
    May 19, 2024
