Headunit wattage question
  • 1
sully8895
7
FL
ok, lets say you have a headunit that says 50x4. really its like 22.5rmsx4. Lets say instead of hooking up 4 speakers you hook up 2. would wiring the two speakers in normally push 50rms watts to each speaker instead of 22.5rms or would you have to take the two sets of speaker wires from the headunit and wire them both to that one speaker to produce the 50rms? and does this even how that works?
what ^ said. amp gain setting info, test tones are at the very bottom...
588
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
sully8895
sully8895
FL
sully8895
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
