headunit with no output
Just sounds like the channels on the internal amp went out...the RCA uses a low voltage output and works off of a different circuit
what ^ said. amp gain setting info, test tones are at the very bottom...
556
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
whojohnjones
whojohnjones
mississippi
outyamouth817
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
