Headunit
  • 2
what ^ said. amp gain setting info, test tones are at the very bottom...
443
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
Hosey760
CarAudio.com Newbie
Hosey760
Victorville California
marc2112
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
