help adjusting levels on new system
  • 3
cinaibur
I'll try and get right to the point. This is my new system:
Kenwood KIV-BT900 head unit
Alpine SPX-17PRO components
Alpine PDX-5 Amp
Memphis 10" Sub
When I turn the volume up to where the sub and my woofers sound good, the tweeters are about to blow my brains out. Should I be making adjustements from my head unit of with the HPF on the amp?
Alright. I'll do that when I get home. I have the LPF on the sub set to 100Hz because it is a shallow mount sub in a sealed box in my passenger footwell. Should I set a filter for the 6.5" woofers in the doors? or is that handled by the crossover as well?
I don't know how you have things wired. If you have the components hooked up to an amp then yeah you should set the HPF to cover the rest of the range set it to around 100 if your speakers can handle that without clipping at the volume you listen to. If they start clipping turn the filter up untill the clipping stops.
Alright. I turned the HPF on and set it to 100Hz, and set the crossovers to -3db. The components sound 1000 times better! I discovered a new problem by doing this though. My sub is not on. How do I diagnose this problem?
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
552
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
565
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
650
cinaibur
cinaibur
Memphis, TN
cinaibur
Decebal
    Jun 10, 2024
