Good Wiring Kits?
jeffburgess10
6
Ohio
Hey everyone. I've been looking at wiring kits for the mono and 4 channel amplifiers I'm buying. I'll consider any price, but I'm mostly wanting the know what will be compatible for my system and what is the best bang for the buck.
Amplifiers:
Infinity Kappa four- 125 watts RMS
Infinity Kappa One 800watts RMS 1600watts peak
I plan on running all kappa speakers in this build with two Kappa 10's. Any suggestions would be much appreciated. And I plan on looking for someone on here to design me a custom box to if anyone is up for the task.. Pro Rabbit said he'd do it, but he bailed on me after we set everything up.
Thanks Everyone
I forgot to mention that I'm looking for 4 gauge power and ground kits that has everything I need to get my setup done.. Distributions blocks included. What I get confused on is the size of fuse i need and how much watts total the kit can handle. One of the amp needs a 80amp fuse and the other needs a 120 amp fuse. Will a 120 amp fuse work for both? This is my first build, and even though I've learned alot about setups I still have alot of things to learn.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
98
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
181
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
395
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
369
jeffburgess10
jeffburgess10
Ohio
jeffburgess10
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
