HELP! Brand new amp, brand new head unit, no sound from subs
so does the light turn on on your amp when ignition is on? Disconnect the battery and let the HU reset itself to default values. Try another set of RCA jacks, have you tried the other head unit yet ? Make sure no speakers wires are touching behind the HU, this will seize all audio from HU. Go to best buy , buy an amp, try it and return it for refund - just use it to test. What about your ground? Is it solid? Is the fuse good on your amp? check fuse on amp and at battery with DMM. Make sure that no RCA's are touching cause this will seize all audio also - These are just a few of the things that I would check....
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
510
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
546
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
578
White94Z
White94Z
Derby, KS
mrpep
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
