Help define Specs
  • 2
johnnyvolcom5
XBL TAG xL BLAZE ix
198
Minnesota
Can someone explain these specs in a simple matter....like what they mean and what you should be looking for when picking out subs. EG FS= 25.0 HZ......FS is.......and a good range is 20-30 (just an example****). try to keep it as simple as possible...thanks.
Free Air Resonance (Fs): 25.0 Hz
Electrical “Q” (Qes): 0.480
Mechanical “Q” (Qms): 7.100
Total Speaker “Q” (Qts): 0.450
Equivalent Compliance (Vas): 2.82 cu. ft. / 79.9 liters
One-Way, Linear Excursion (Xmax)*: 0.65 in. / 16.5 mm
Reference Efficiency (no): 0.250%
Efficiency (1W/1m)**: 85.9 dB SPL
Effective Piston Area (Sd): 77.8 sq. in. / 0.0502 sq. m.
DC Resistance (Re): 6.75 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 600W
Driver Displacement: 0.090 cu. ft. / 2.5 liters
Net Weight: 19.4 lbs. / 8.8 kg
143
445
423
johnnyvolcom5
XBL TAG xL BLAZE ix
johnnyvolcom5
Minnesota
Logikalliquid
    Jun 1, 2024
    May 31, 2024
