Help, Diagnose this two way remote problem with viper 5701
  • 4
bigdano
Hey all
Whenever I press the unlock button on my two way remote, the truck chips twice like normal, then two to three seconds later the truck emits an additional chirp and my two way remote beeps a high and then low tone repeatedly for like ten seconds.
There has got to be a known solution on this.
Dan
Low transmitter battery could be the problem, however I JUST replaced the transmitter batteries 5 minutes ago, and I am not sure if the remote beeping twice repeatedly is the indication of low battery.
I think I figured the problem out. The remote is a piece of ****. The brass holder that holds both batteries in place was pulled back a bit from getting old batteries out. This caused a bad connection with the batteries in the remote. I bent the brass down some, so it would exert more downward force on the batteries holding them in the remote further.
I think this solved the problem.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
189
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
464
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
455
bigdano
bigdano
St. Louis
AVX Mike
