Help enlosure for american bass hd844
  • 4
Simonusa2010
Ct
Hi maybe you guys can help me
I'm looking to build a perfect box for my American bass hd844, i looked online and couldn't find any information about the speaker I did receive the spec sheet along with the speaker but the parameters are off, because when I input them into winsd how me box like 8cu ft it doesn't show up correctly any input appreciated!
if you gays can do some suggestion i need
box net vol.
Port vol
Tunne
They go to sedan car in the trunk
Amp around 750 watt
Hi maybe you guys can help me I'm looking to build a perfect box for my American bass hd844, i looked online and couldn't find any information about the speaker I did receive the spec sheet along with the speaker but the parameters are off, because when I input them into winsd how me box like 8cu ft it doesn't show up correctly any input appreciated!
box net vol.
Port vol
Tunne
Amp around 750 watt
Build a tline for a single 8 if you have the room. That will give you the most output with the widest bandwidth.
Sent from my SCH-I605 using Tapatalk
I agree with cscstang, t-line would be the way to go. Build this and profit.
If the dimensions don't fit your ride, post your max dimensions and I'll re-design it for you.
Sent from my SM-G925K using Tapatalk
Hmmm this is too big but thank you for suggestion. I need some trunk space
This is largest box what i can fit h12.5 x w25 x d13
My laptop is out of commission so I don't have a way to do a sketchup, but here's a great design for it.
0.85cuft@31.95hz with 15.61sqin port per cube.
21" wide, 12.5" tall, 14" deep.
Port is 11" tall x 1.25 wide x 37.5" long
Box will have 3 port panels and it'll look similar to this.
Sent from my SM-G920T using Tapatalk
Ok im little confusing when i calculating i have different result then yours
12.5h
21w
14d i thing 2x.75 wood yes?
This give me 1.459 cu ft total
1.25x11=13.75 port area
37.5 long
Port displacment are .477
1.459-.477=.982 cu ft
.982 - .06 (speaker displacment) = .922 cu ft net
And when i put this number to the web program to calculate port leng
.85 cu ft 1.25 x 11 port dim with slot port show me 34 inch long
Where i did somthing wrong with my calculation?
191
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
562
395
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
367
Simonusa2010
Simonusa2010
Ct
Simonusa2010
    May 18, 2024
    May 16, 2024
