Help/ideas for amp rack design in a Jeep.
  • 3
infowarrior45
I need some ideas for mounting my amps in a '98 Jeep Cherokee. I have a Reference 650.6 and a Kicker ZX1500.1. The Reference 650.6 is almost 3 feet long, so you can't just put it anywhere. I have a sub up, port back box, so mounting on the top or back of the box isn't possible with the Reference 650.6.
My idea right now is to make a recessed amp rack and lean it against the front (I call it back) of my sub box, facing the front of the car. I would keep my seat down most of the time so I could see the amps, but would have the option to put it up for carrying passengers.
This is sort of the idea. I'd appreciate any suggestions or alternatives.
If you have the depth, you can enclose them as well, with proper ventellation, or use a fan cooling system hooked up to the electrical. For instance, put walls around the rack base and either top it with a plexi look or keep the top open. Would look cleaner than putting amps on a board alone. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yes, I am definitely going to enclose them. I was planning on basically having them flush mounted in sort of a box. Then I was planning on lining the edges around the amps with blue LED's and throwing a fan in there as well.
I need some help with the enclosure design. I obviously need access to the inside of the rack for mounting the amps and wiring them, so I was thinking of having the front face hinged at the bottom?
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
191
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
564
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
395
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
368
infowarrior45
infowarrior45
St. Paul, MN
infowarrior45
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
