Help Me Choose 8s
Icecube91
Im looking to do two or three 8" woofers in my jeep and need help choosing some out. I want something that will get loud but will have great sound quality. I have been doing a lot of research and came up with a lot. Also when looking at a woofers T/S parameters what do you look for?
Sundown SA 8
Sundown X 8
DS18 EXl-X8
B2 Audio RageV2 8
B2 Audio Rampage 8
Cosmo Audio EP500 8
CT Sounds Strato 8
CT Sounds Meso 8
Kicker L7 8
Toro Audio Force 8
SSA F8L
I don't think you will be able to hear a difference between any of those subs other than the L7s. I've never been a fan of L7s sound and I have had them and run them in many different boxes.
I personally would probably go Sundown SA or SSA F8L. My SA-8s were top 3 subs I have ever had.
Agree with Pop. My top 2 choices in there are the SSA F8L and SA. If/when I run 8’s, I will likely be going the SSA route but, I will give Sundown a hard look as well.
I have no experience with the F8L but SSA woofers tend to be a bit more “musical” according to others.
I was looking at the b2 audio because spec wise they're all pretty much beefy in every category than the other 8s
Does having beefy TS parameters not mean anything
You would personally run SA8 over the x8s
T/s parameters don't always translate to a better woofer. There's some woofers that look better than others in that department, but some woofers are built better than others too.
The sa-8 is a really good woofer. I know you know what I think on that lol.
B2 stuff seems legit. I want to see more people run it. I was supposed to be doing a b2six series 6th order but it hasn't come time yet. The b2 stuff seems impressive looking at it, I'm just not sure about overall quality because it seems like nobody uses them.
The X8 is an SPL woofer. The SA is the lowest distortion 8" ported subwoofer Sundown has.
In our line all of the 8s are unique to their line.
The X-8 is more of a "traditional" sounding subwoofer -- not an ultra high-excursion, linear, bottom-end monster like the rest of the X series.
Granted it can still play low but it's not going to sound like the rest of the X line.
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
4
Sub should be in the cargo area for best results. I'm skeptical about those unknown brand Chinese head units myself and would stick to known...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
164
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Icecube91
Icecube91
Vancouver, BC
Icecube91
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
