Please help me choose the right amp for the job. Thanks
  • 1
Belwri
CarAudio.com Newbie
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup. Here are the specs: https://www.skiptoncarradio.com/bla...it-vw-transporter-speaker-upgrade-13454-p.asp
The woofer will be the 8" Blart (using collar to upgrade from standard 6.5"). It says Max 200w, nominal 100w. Impedance is 3 ohm.
I don't really know how to choose the right amp because most of them seem to run in a 2ohm or 4ohm capacity. Also, is nominal RMS? 100w RMS seems a lot for an 8" speaker of about £200?
Could someone explain how I deal with the ill matching impedance issue that most amps have, and also suggest a non budget, middle of the road amp that would do a good job of running the Blarts without over or under powering them.
I have a 12" Alpine boxed reference class sub that I will be adding into the mix later and a D class mono amp to run it, so all I need is a decent 2 channel amp to run the front L&R as I wont be adding rear speakers.
What would you install? Thanks
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
894
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
885
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Belwri
CarAudio.com Newbie
Belwri
Shoreham-by-sea
Belwri
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
