Help me with a pair of Skar ZVX 8's
  • 1
ilikeradios
I just picked up a pair of these.
They are dual 2 ohms so I will have to run them at 2 ohms on my RP 2000.1
I am putting them in my Ford Sport Trac
My rear seat folds down into a flat platform.
It is a 2/3 split.
I want to remove the larger side and build a box, this will allow me to put one person in the back when needed. The rest of the time the back is just for my dog and cargo.
This is basically the setup,
So anyway I am surprised the subs require so much airspace.
Skar says 1.2 cubes each, that is pretty big.
I am thinking a pvc tube is the only way I am getting a port to work.
So thinking subs firing forward and the port sideways firing towards the rear door.
How much room should I have between the subs and the back of the front seat, I am hoping 2-3 inches is enough?
Thoughts?
so 8's facing forward firing into the front seat, how much room between the subs and seat?
Port firing towards door, how far away should port be from door?
2-8's on around 1,200 watts, is that enough? They can handle 2k but I don't have the correct ohm load.
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
I still have some Old school stuff that I really enjoy to this day. I still swapp amps and other gear I have from time to time and run for a...
17
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
190
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
559
ilikeradios
ilikeradios
Pigeon Forge, TN
ilikeradios
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
