Help? Ohms? amps, subs, Im lost, lost, Lost!!!
  • 1
damnbusdriver
ok I'm putting a system in my bus, I'm really stoked about it but I have researched this stuff so much I am lost? Somebody please tell me the best way to hook everything up? I have two JBL 6x9s that are going to be in the front of the bus, Four JBL 6 1/2" speakers that are on each side of the bus, Two JBL 12" subs that are in the back of the bus.I should mention the subs have switches on them so you can change the ohms from 4 to 2.
A Pioneer radio with rca's for front, back and subs. I have Two Pioneer amps to run everything?
All this ohm stuff is confusing? do I run a set of wires to each sub? Maybe 1 sub on each amp? do I run one set of wires to both subs?
I know somebody just knows this stuff right?
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
202
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
612
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
400
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
374
damnbusdriver
damnbusdriver
Beloit, WI
damnbusdriver
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
