Help Please
  • 2
BRITBOY
10
LA
Ok, I have just installed my Panasonic CQ-C8803U along with some CDT EF-61CF 6.5" comps powered by Clarion DPX 2250(125w x 2). Sound is excellent, apart from my rears are "popping" when volume is turned up. So I have ordered some ALPINE SPS-57C2 for rear fill which I am running of the HU (HU has 31wrms) So I have my HPF and LPF on my HU turned off and have my amp's HPF set at around 80-100hz.
I have a couple of questions,
1) does this sound like I have everything set up right?
2) how do I control what my rears will play?
3) should I use my HU filters instead of amps?
I have no sub (yet)
i would use the x-overs on the headunit. more accurate and depending on amps you can achieve a better slope, like 18db or 24db.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
954
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
BRITBOY
BRITBOY
LA
dgr00s
    May 16, 2024
    May 16, 2024
