Help Wiring Car Amp Inside Home
  • 3
CpsChase
I've looked up a TON of tutorials on how to do this but I keep running into a problem. In all these tutorials the amps that are used are able to have a fuse plugged directly into the amp. I have a Rockford Punch 600x4, and It does not allow that feature. If I buy a PSU that has a fuse in it, would that bypass not having a fuse for my amp? Or must I use an amp that does have the fuse plug in feature.
Why not buy an appropriate home receiver?
I have done this in my teen years. Simple solution is buy a power supply. Then go from there.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
685
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
CpsChase
CpsChase
Houston, TX
Boomin_tahoe
Decebal
    Jun 10, 2024
