Car Stereo wiring help
  • 4
DonJohnson
CarAudio.com Newbie
AZ
Hey guys, I am attempting to swap out old aftermarket stereo with new stereo. The existing wiring is a bit of a nightmare. I am not sure what the wires heading off to the right and left are for. Perhaps the wire to the right goes to battery for constant power but what are the wires going towards steering column? I was hoping i could just plug the new harness adapter into the plug in the picture but it looks like it won't be so easy. Car is 2007 corvette without bose. Thanks
That 13 pin might be for an ipod, the one for the column may be a steering wheel volume control, the peripheral is a mystery. Radio harnesses are interchangable among common brands. Check the harnesses that came with your radio to see if they are similar.
thanks for the reply, i appreciate it. It is strange i have no steering wheel controls at all but there are 5 or so wires that go towards the steering column..
Usually, stereos come with a wiring diagram. Did yours?? Have you looked for YouTube videos that cover your particular situation? Crutchfield.com also offer spectacular support service. They even sell a wiring harness that fit your particular situation. Good luck.
Thanks for the reply. I ordered an adapter that should just plug into the harness and be good to go. However i do not know what to do with all the extra wires going towards steering column and if they can all be cut and capped off, etc.
If you are not using them. then cap them off
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
You can go to theyre Website and check it out/do some research on your own, or even give them a call
33
6K
It should be called the accessory wire...it should be connected so that it only see power when the car is on...if its connected to constant power...
792
Unless Android made some big changes to their core program, it should work just fine. Just like using a 4g phone on 5g sevice.
Should be good to go without those fuses. Read the manual that comes with the new stereo. If it doesn’t say to add additional fuses, don’t.
DonJohnson
CarAudio.com Newbie
DonJohnson
AZ
audiobaun
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
