help with 3way crossover set points
BlackMaxima
LA
for my 3 way front stage this is what im thinking about getting
Tweeter: Scan-Speak Illuminator R3004/6020
Midrange: Fountek FR135EX
Midbass: Peerless SLS
for crossover points this is what im thinking, and then from there ill start tuning and making adjustments
Tweeter:6500khz to up
Midrange:160hz to 6500khz
Midbass:60hz to 160hz
Subs: 20hz to 60hz (IB in rear deck x2 12inch Idq v3)
TY
Locations?
Locations will be
Midbass: in the doors
Midrange: in a kicks sealed
Tweeter: in pillars
I might change the mids from Fountek FR135EX to Hi-Audio Prolific
here is the link
http://www.haudioincus.com/Acappella-Series.php
powered by:
1) ArcAudio KS 300.4 (90X4 for the twets and midrange)
1) ArcAudio KS 300.4 bridged ( 350x2 for the midbass)
1) ArcAudio KS KS 1000.1 for the subs
That's an expensive tweet and you're not planning on crossing it over low. IMO, I'd look at a more affordable tweet, maybe the Peerless HDS or something.
Affordable is subjective. There's a huge size diff.
Anyhow. With the listed mids and tweets you have a wide range between them that you can cross them. That's a very low FS tweet and the fountek extends very high (fullrange iirc.)
With those locations, the higher the midrnage plays, the more problems you might have with stage height, however, some argue that the mids should play the whole vocal range.
Those xover points you listed sound like a good starting point, though I would probably cross the tweets lower.
No one can really give you specific xover points to use. Its best to tinker and adjust, trial n error, to see which sounds best and suits you.
As long as your speakers are playing safely within their limits, then you're fine.
thanks james
I just want to have a starting point and then from there ill start to tuning it
ill just start with this
Tweeter:2000khz to up
Midrange:160hz to 2000khz
BTW james i got a tread on DIY mobile audio
http://www.diymobileaudio.com/forum/diy-mobile-audio-sq-forum/72586-my-first-3-way-i-need-some-help-plz.html
if you wanna come and check it out
2khz(i think that's what you mean) would be the lowest I'd recommend for that tweet.
...no thanks on that diyma stuff. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Play around with the lpf on the midbass. You could probably raise it up just a little bit too. You're also going to have to fool around with the slopes. The only one I can definitely say is to put the steepest slope on the tweeter hpf. Also, I've heard many times that a nice slow rolloff from the subs to the midbass helps out the usual difference in output between the subs and midbass. I kinda like it too. The rest depend on you.
Any reasoning behind the steepest slope possible for tweets, blue?
Just was I was told over and over (for the lowest recommended xover point). I don't have any tests done on it but its probably due to the mechanical limit of the tweeter right? Also, it seems to me that the octaves in that range cover a wider range of hz so that less overlapping will be the result. Some like it I suppose, I've tried it but went back to steep. If my mid and tweeter were closer (side by side possibly), or if I changed the power going to the speakers, or just a couple other eq adjustments might make me reconsider having a default steep slope. I'm not quite there yet, still a novice.
with tweets having fs of 600-1khz, you can have common xover points of 2.5-3khz+khz and use shallow slopes safely.
Remember, the slopes messes with the phase.
Amen to that. I was experimenting with this very topic maybe a month ago and it wasn't sounding very nice at all.. more like a ringing on certain frequencies. I quickly stopped that and set it back to what I liked.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
532
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
554
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
625
BlackMaxima
BlackMaxima
LA
ice_audioworks
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
