Help with Amplifier???
  • 2
Str8No0bDntH8
CarAudio.com Newbie
Was moving box & amp around in back of truck, in process of doing so some how the amp's RCA's ports got damaged. I disassembled Amp to repair(tried to solder) rca ports but not sure what step doing wrong.!!! Any help/pointers/suggestions would be appreciated!!
~thought~ Is there anyway to still get sound from head unit to speakers without using RCA's???
Pics would help.High level inputs can be utilized if need be.Follow those steps in the manufactures manual.Id recommend getting a repair shop to attach a new set of RCAs if damaged.Some Computer repair shops will do it.Just a recommendation
564
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/
6
703
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
4
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
Str8No0bDntH8
CarAudio.com Newbie
Str8No0bDntH8
Arizona
audiobaun
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
