Help with determining RMS output .
  • 6
AdamC
19
Indiana
Hey guys I'm trying to determine the output on my brothers build . He's currently running 3 SKAR IX 10's on a 800 watt mono in a sealed enclosure . From everything I can gather off a volt meter , the final wiring impedance holds steady at just over 2.5 ohm . The amp is rated at 600rms at 2 ohm , but dyno's at 710 on a certified test at 2 ohm and uncertified at 808 2 ohm . Would I be safe to say each sub is getting at least 225 rms on the low end ?
I'm asking because the subs are low rms rated at 200 each ( " conservatively " ) . I really don't think he gives a **** however I'm an auto tech so I deal with electrical on a daily basis and I can't seem to figure out the formula for this one for a somewhat accurate measure .
yeah like darth said probably 150 each at most.. 1 better sub in nice ported box be better on that amp i'd bet..
You need 2 tools. A multimeter ac voltage and a clamp meter that has ac amperage you can times the 2 measurements to get rms Power and divide the get rise
That will give you VA, not RMS.
Based on the power factor at the time of the given clamp, VA can be as much as double that of RMS but VA will never be below RMS, always greater.
Is that even with a true rms clamp meter? And if you take the readings from the output side of the amp, how is it not rms?
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
359
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
508
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
517
AdamC
AdamC
Indiana
THATpurpleKUSH
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
