Help with Kenwood cassette deck in girlfriend's car!
  • 2
Help me! I have a 1999 Kenwood cassette reciever (model #KRC-235) with the disc changer av inputs on the back along with the amp preouts. I was wondering if you could plug in a standard wire with the avs on one end and a headphone plug on the other in order to connect a personal cd player to it and have the cd player on the conter console with the wire discreetly coming out of the dash and be able to have it play cd's from the cd player into the deck and out to the speakers. (I know that it sounds rigged, but it's only a temp fix until I install a new deck.....the cassette mechanism doesn't function, so a tape adaptor is out of the question...)
yes that should work however be sure you don't plug the jasc into the headphones out on the cd player plug it in to the line out.........The only thin I am not sure of is compatability. The portable and the deck may speak different languages........try it though and see what happens .....what do u have to loose if the tape deck is already broken and as for the new deck layaway is a beautiful thing
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
644
I have a seat Leon 2010 1.6tdi it’s fitted with a seat unit that won’t load sd card internal error so bought the above stereo to upgrade and a...
I would call Kenwood Tech support. Im sure they will try to help you
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
500
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
forum_punk
forum_punk
Northfield, Minnesota
gregj9
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
