Help with keyless entry on new alarm
  • 2
N2DEEP3D
I have a 1993 Dodge Dakota and I recently bought a Soundstream AL1 alarm plus keyless entry.
After doing the base install my keyless is not working.
Here is the wiring for the door locks:
Power Door Lock Negative Wire (-): Orange/Violet (5 Wire Reverse Polarity)
Power Door Lock Negative Wire Location: In Drivers Kick Panel, Black Plug Behind Fusebox
Power Door Unlock Negative Wire (-): Pink/Violet (5 Wire Reverse Polarity)
Power Door Unlock Negative Wire Location: In Drivers Kick Panel, Black Plug Behind Fusebox
My Sound stream alarm installation says:
Pin 1- Green Wire- Negative Lock Output
Connect to lock wire from the switch on vehicles with a negative type switch.
**LOW CURRENT ONLY**
Pin 2- 12volt Output for Door Lock Module
This output will supply 12volts for a plug-in type door lock module. Do not use this input to powerup
relays **LOW CURRENT ONLY**
Pin 3- Blue Wire- Negative Unlock Output
I have it hooked up green to orange/violet and blue to pink/violet, but it is not functioning at all.
I am wondering if I need to add relays to make it work, but just by reading it looks as if it should work as is. Any help would be appreciated.
Gary
Just to make sure you are saying to do the 4 Wire Reversal Door Locks?
I have no problem doing this, just want to make sure before doing all of the wiring.
By the way, thank you. ALOT!!!
Gary
I have fought with this for a week, and the 4 wire reverse diagram you said to use does not work.
My dodge is a 5 wire reverse polarity system.
I tried the 4 relays wired together and set as the diagram said. I hooked the lock and unlock wires off of the relays at the lock side of the connection plug and after, neither work. The best results were had when I went directly next to the lock actuator on the driver side but when I hit unlock the passenger side hummed like crazy and did not work properly.
Anyone else with a suggestion.
Well found the error, guess I was just too literal when you said second one down. It was the third diagram down. Finally got them working correctly...was also on my last fuse lol.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
187
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
556
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
392
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
367
N2DEEP3D
N2DEEP3D
Magnet Cove, AR
N2DEEP3D
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
