Help with port size/ tuning please.
  • 2
C-Loc
I just built a box for my alpine swx 1242d. The boxes dimensions are 13.5H x 25W x 15L using 3/4 in. MDF. And I'm putting a slot port in on the left side of the front peice. So my port would be the height of the box. I want to tune it to 24Hz. This is my first time tuning a box and I'm a little confused and I want to do this right so any help would be really appreciated. How wide should I make my port?
Tuning it at 24Hz? More like 35Hz my friend. Just remember, a "ported" box with slot ports is bigger than one with tube ports. The dimensions given is roughly 2.2ft^. You still have to account for the volume of the port itself.
It depends on the car you're putting it in. Space may or may not be factor.
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
None so far, there was a factory 8 inch subwoofer that I took out for a pass through, I'm definitely going to have to get some sound deadening...
10
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
78
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
126
C-Loc
C-Loc
United States
nvturbo
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
