I am sure there are lots of discussions on this topic of a high pitched noise coming from the speakers. I read some and couldn't find an answer that helped me.
I don't believe this is engine noise because the noise hasn't always been there. I used to run a rockford fosgate 4 channel prime amp until it toasted, so I swapped it with a 4 channel Infinity kappa amp. That is when the noise started; it did not exist when the rockford amp was working. Therefore, i do not believe it can be a wiring issue since i didn't reconfigure any wiring from when i first put it all in (separated power from audio cables), but correct me if i am wrong.
Does anyone know anything about these amplifiers? Perhaps setting adjustments?
thanks
thanks
