help with system choices
elcoco210
I currently running 8 ma audio 10s tuned 36hz off a power acoustix 5500 bamf. My girl had found a crescendo bc5500 for me and bought it so now I'm thinking if that would be to much amp for 2 18s I'm thinking about the IA death penalty 18s .5 ohm each for a total of one ohm or psi platform 3 18s have two kinetic bats only one is in use right now and the big 3 done what I need help with is will I need a higher output alt. Or is it to much amp for those subs if it is I'm open to suggestions of other 18s in the same price range and if anyone thinks I need to upgrade more electrical let me know any help is appreciated
You need a high output alternator and probably a couple more batts to be safe. I think the PSi platform 18's should handle the power fine. Or the SSA Evil 18's, I don't see why the death penalty's wouldn't handle it, and I'd imagine the HDC4's would handle the power as well...
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
758
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
989
Sorry, didn’t watch the video the first time for some reason. Supper helpful video. I will try that. I guess the RMS rating is oversimplified...
Have you talked to him about the electrical? I really want to get deep on this, but lets see how this goes. When you add that amp, you add...
953
elcoco210
elcoco210
San antonio, Tx
SounDrive
audiobaun
    May 19, 2024
    May 19, 2024
