Help with upgrading...
  • 3
tundra1221
I was thinking about doing the big 3 and getting a new battery....it's the big 3 really as simple as just replacing and relocating power and ground cables? Details please and how big of a battery can I get for just my stock alternator? thanks
Big 3 is adding wire. No need to replace/remove what's already there. Are you trying to add a second battery or replace your current one?
Idk what are the pros and cons of adding vs replacing?....I just know I need more power from the battery before I add more ****
well adding is just that adding the existing stock wire will still carry current @its usual rate and the "new " run will also carry current .. so basically ur just opening a new road for current w/o closing the old one.
the main purpose for a "big three" is to help ur electrical system be slightly more efficient it is mor about the grounds "frm the alt case, or braket to the frame and the battery neg to the frame"
Do a lot of research using YouTube videos and other audio sites/forums. I also purchased several books on aftermarket stereo off of used books...
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
95
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
136
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
241
tundra1221
tundra1221
spokane, WA
tundra1221
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
