Help with upgrading...
tundra1221
I was thinking about doing the big 3 and getting a new battery....it's the big 3 really as simple as just replacing and relocating power and ground cables? Details please and how big of a battery can I get for just my stock alternator? thanks
Big 3 is adding wire. No need to replace/remove what's already there. Are you trying to add a second battery or replace your current one?
Idk what are the pros and cons of adding vs replacing?....I just know I need more power from the battery before I add more ****
well adding is just that adding the existing stock wire will still carry current @its usual rate and the "new " run will also carry current .. so basically ur just opening a new road for current w/o closing the old one.
the main purpose for a "big three" is to help ur electrical system be slightly more efficient it is mor about the grounds "frm the alt case, or braket to the frame and the battery neg to the frame"
Do a lot of research using YouTube videos and other audio sites/forums. I also purchased several books on aftermarket stereo off of used books...
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
60
576
tundra1221
tundra1221
spokane, WA
tundra1221
