Help with voltage drop
  • 3
Colossus281
OK I have a brz-1700 at 1ohm stock alt it does 140amps I have the big 3 and a sk bt-60 battery along with the stock battery. When playing my music my lights **** if I add one more sk bt-60 would that help? And they are good for 1400watts if there's two would it be good for 2800watts? I'm kinda stuck since they don't make a high output alternator for my car yet thanks
wrong place ,add another battery and the big 3
Wrong place = tru dat
But he already noted he had done The Big 3...
I would have thot that the stock alt + Big 3 might have been enuff , especially with the added batt.
You sure the grounds are solid? Good place to experience voltage drops, if not done correctly.
Also, what size wiring did you use on The Big 3 upgrade?
Wrong place = tru datBut he already noted he had done The Big 3...
^^^^ this
Everything is done in 0 gauge and I double checked on my grounds when I put it in with dmm ya I just notice I put it in the wrong place sorry doing everything with my phone
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
618
Or stick with older vehicles that don't have stupid **** like that.
5
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
376
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Colossus281
Colossus281
Albuquerque nm
Colossus281
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
