Help with voltage
  • 4
Because the voltage does what it wants and I would like to keep my voltage steady full tilt lol
If you are referring to an aftermarket amplifier power source, it's not controlled by the PCM. Wiring is direct from the battery to amplifier. The amplifier controls the power. Your stereo control the signal to the amplifier, and the PCM controls the signal that turns the radio on. Not sure if it controls the power or signal output of your stereo.
Let us know more about your setup, so we can provide more accurate advice.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
374
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
106
deehorton1989
CarAudio.com Newbie
deehorton1989
Durant, oklahoma
metalheadjoe
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
