Will a better battery help subwoofer being too strong? Alternator voltage 12.8
  • 4
Ali2627
2015 acura ilx 2.0L engine
Hi I have the Rockford p300 10 inch 300w sub and 100w HID kit along with 2 dashcams and a phone charger and tiny things here and there. My car with max accessories and sub going the voltage at the battery gets at 12.8 V and when i turn it off some stuff it goes to 13.8-14 V I have a flooded battery will an AGM battery help here or is my alternator just took weak? My car is having starting problems I suspect it's the starter but now after this testing maybe this is why?
Didn't happen before this started about 5 months ago maybe the battery is getting older?
Car battery is 2 years old
Group Size 51R
500 Cold Cranking Amps (CCA)
RIP projector bowls. :ROFLMAO:
What do you mean by starting problems? Like doesn't want to turn over? What is voltage while cranking?
Haha the projector bowls are fine thankfully. Yes sometimes car doesn't start
did some tests also autozone tested battery was fine they said my alternator was bad somehow but i dont believe that. I suspect since my battery is flooded its not as effect to recharge and cycle compared to AGM and my car under max load weakens the battery but doesnt kill it enough for rare times the car wont start where i gotta click on and off a bunch until I assuming here builds up enough power in the starter solinod to get it started.
Car off battery reads 12.63 V
Car when being started (battery load) 11.08V
Car running with max accessores on 12.85V
Car running with no accessores 13.8-14V
SOOOO my question still stands anyone know a good AGM battery? thats size 51R with more than 500 CCA?
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
11
2.5 cubic feet per subwoofer not total. Those X's require some room.
7
769
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
12
Alpine, and it's not even close. I own that Alpine unit and the 9-band parametric EQ is much more useful than the 5-band graphic on the...
Ali2627
Ali2627
Los Angeles,ca
Bobbytwonames
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
