Help
  • 2
check your amplifier ground, your headunit outputs might be wired incorrectly or your headunit may be grounded improperly or your headunit could be bad
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
378
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
515
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
523
marepare
marepare
North pole
wew lad
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
