Helpful Opinions Needed!
  • 3
I have a 1999 Chevrolet Suburban. I have 2 15 inch Kicker CompVRs powered by a Kicker ZX 1500.1 amplifier. The system sounds amazing but I am having a problem with it cutting out at very high volumes. I have already fried the MOSFETs in the amp once. I know that my problem is that I'm not getting enough power to my amp. So my question is what is my best option/s to increase my electrical supply to my amp so I can see how hard my system can truly hit without my volts dropping and putting my amp in danger. I would also like someone's opinion on making the choice between a Super Bass Pro Box or a Custom built box that will be designed and constructed to the actual specifications recommended by Kicker.
get a custom build box made to suit your subs/amp/car.... it'll make a huge difference. and be sure to set your amp up correctly (search on how to set gain,bassboost ect) the kicer zx1500.1 should go into protect mode If It gets low voltage
---------- Post added at 12:25 AM ---------- Previous post was at 12:24 AM ----------
do have you have any pics of your system atm?
I would not add 6s yinglong to 5s titan8/scibs. Personally I wouldn't do 5s lto at all yinglong or titan8/scibs. Since 5s maxes at 14v and...
991
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
8
808
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
Ike_Turner
Ike_Turner
Hattiesburg, MS
mylows10
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
