Hey, New audio system in car... Need help!!
keankrer
Hi i need help for this audio system. i am completely new to this and need help with pretty much everything. What is the best way to wire it? (parallell or serial) what amplifier that would fit best for this system? what size wires i need and fuses? i think i can find out most of this on my own if just someone could explaine to me what i need to look for, or measue out and stuff like that. as i said im copletly new to this and dont know much.  Also what is my cheapest option, dont really want to spend much money on this right now.
link to all products:
https://www.hertzaudiovideo.com/car-audio-coaxials-dieci-dcx100_3/
https://www.pioneer-car.eu/eur/products/deh-x7800dab
the 6"x9" speakers are some old ones and all info i have about them is this:
57284409_467497813791072_7839784511842811904_n.jpg also i mesured 4 ohm on them.
my uncle has this amplifier that i can buy from him but i dont know if i can use it: https://www.pioneerelectronics.com/PUSA/Car/Amplifiers/GM+Digital+Series/GM-D8704
your first resource is www.bcae1.com.  An excellent source for you to start understanding what and how to get going in DIY car audio.
It is recommended to stay with the same brand and product line with front and rear speakers so they sound the same.  Either Hertz Deci or Pioneer are ok choices.
An aftermarket head unit is an important piece as it determines what features you have and what sound quality you start with.  Kenwood is a good choice here.  You pay for features.
The amp you linked is compatible with an aftermarket head unit (via RCA cables and remote turn-on wire).  Power wiring install methods are important to research and require a fuse holder at the battery with insulated connections and safe routing that follows factory routing.  When in doubt, it should look like it was installed by the factory.
but will what i linked work fine together, as long as i use the right wires and fuses or is there any better combinations? i have all the components linked in the post already, im just missing the amplifier.
The pio amp would be great, even ideal.
It is much more powerful than the 4's need, keep the gain low and the high pass filter pretty high.
There's no series/parallel issues.  It's a 4 channel amp with 4 speakers -- a speaker on each channel.
ok thanks
The dirtiest hooker allive gotta smell better than fried Epoxy! (okay, that was a tad bit nasty, but funny nonetheless!)
hey
If it is a DVC4 ohm sub.. you can wire it up to a final 8 ohm load to run on that amplifier.. If its a DVC2 ohm sub... you can wire it up to a...
Pretty interesting interview/debate
550
  • Poll
That strikes me as overboard. We'll probably survive if a thread or two every week comes back from the dead.
18
keankrer
keankrer
keankrer
    May 16, 2024
    May 16, 2024
