Hi! Quick question here!
  • 2
Ok, so when you hook your wires to your amp ( power+ground+speaker wires) that has set screws to secure them in place, do you add some sort of connecter to the end or maybe you are soldering the ends before or just put them in there as is and squeeze the multiple wires?
Thanks
Thanks
Just squeeze them in and clamp down. You don't want to solder unless you know it will fit after they are soldered. On 1/0 wire, I like to use a zip tie near the end hen i get the wire in the hole i just cut the zip tie push the rest in and clamp down. Keeps from having stray wire.
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
970
i have no experience with component speakers. Maybe someone else can help in this area.
soundstream5ch
Qc, Canada
CSCStang
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
