Hifonics amplififier repair? can i do it myself if so how?
  • 1
heathfreyou
I have a class A/B 800W RMS, Zeus Series 2-Channel Amplifier (ZXi 200.2) and from the moment it arrived on my doorstep it was broken i had to send it back to sonicelectronix and they claimed it was not broken and had only been bench tested yet the warranty seals were broken so obviously they fixed it charging me a shipping fee and voiding the warranty on it. the amplifier broke again and its the same problem everything works except it makes no sound. I'm pretty sure the problem is on the circuit board because the amp got really hot then stopped making sound. the power light still lights up but dimly and the blue Hifonics symbol still lights up. what could the problem be and how could i fix it?
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
heathfreyou
heathfreyou
Thibodaux, LA
heathfreyou
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
