Hifonics Amps
Sweet. I heard from the rumor mill the Brutus line was designed by Zed Audio, is that true
I believe they were modeled after the zed made lanzar optis... I don't think hifonics has been zed made since the 90's... the v series or something. This is a solid amp though... google for some gut pictures.
Just ordered one. Thanks for the help
At the risk of sounding ignorant what exactly do you mean by that?
You will likely need to do electrical upgrades. Youtube the big 3, get yourself a 2nd battery and stay away from capacitors and get yourself a voltage meter. You want to stay as close to 14.4v as possible. You don't want to go below 12v. Use 0 gauge wire for the install and big 3. Welding cable also works well (2/0)
What cfox10 said basically.I ran the brz2100 for about 2 months.Definately run 0 ga wire and big 3 with an extra battery.Amp can be a power hog..Good luck!
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
438
boltdbz
boltdbz
Anchorage, AK
Jes 42
