Hifonics Colossus
joeu3
SOLD
Hifonics Colossus
3200 watts blah blah blah
I'm sure you guys know..
Used, works perfect. The pictures make it look super clean, there are some very minor scratches. But, still looks just fine.
I'll include all my wiring for it, 1/0 awg and the 300 amp fuse.
I'm also selling my sub, it will be listed in the sub classifieds..
Hate to see this go but it's time to move on..
Just pulled it out of my truck yesterday..
$300
I guess depends on location.
~$25ish
Thats a nasty amp. What car did u have this in. Just got the brz2400. Did this amp do justice for your cerwin 15? Have u ever clammped this amp. Curious migjt want to buy. Is this thing power hungry. Did u need a ho alt to run this.
of course it did, it does rated, yes its power hungry, and yes you do.
p.s great price. holy **** hah
u will definitely need to upgrade your alt., otherwise even with two batts, I doubt you'l get a few hard hits before you start to run under 12V.
If you check out my gallery I have pics of my setup there. As a daily I had it wired at 2 ohms (one channel per vc) and when I felt like showing it off, u can see in the wiring pic, I made a quick bridge to drop it to one ohm. This amp, I would say, is all I could ask for to push my stroker without really breaking the bank. Stroker sounded awesome at low levels and crazy turned up. Never had a problem with the amp.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
joeu3
joeu3
florida keys
joeu3
