High pass frequency on Midrange speakers
  • 3
You need to re-phrase the question. Are you trying to use active bi-amplification via outboard amplifiers or do you just want the recommended...
.Run HU at full pass, cross HP filter on the amp at 40-50Hz - or - Cross the HU at 40-50Hz and amp at full pass. I prefer to adjust prior to the amp
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
92
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
655
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
579
ianik777
CarAudio.com Regular
ianik777
Mauritius
ianik777
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
