holy SMOKE!
all right well i'll keep you posted i'm not sure how things are going to go between now and then... but i'd really appreciate the help
Just to keep you updated. I'm meeting with a lawyer next monday, he's gonna write a letter first. If that doesn't show anything then we may be going to small claims court.
I lost 400$ out of a audio shop.
Keep everything documented. Trust me and learn to do thing on your own. It is the best bet out there.
Good luck.
Hmmm a 1 week rush job that ended up damaging your equipment. Sounds like you have a case against these fuxors. A professional install should most definately include gain settings as thats a very critical part of any system. Why would they put a gain control on an amp if its not important, it directly effects how much power the amp puts out and is used so you don't blow anything.
I personally would've thrown a brick followed by a molotov through the front window after he tried blaming it on me.
Anyways I hope it turns out for the best, and just so you know I learned how to install my system in about 2 weeks and went from knowing very little to a lot. So its not that hard to do yourself next time and you know its done right plus all that hard earned money you get to not donate to some prick that takes advantage of his customers.
Yeah, I'd give them a call. They might replace it. If they do, that is huge CS. I've never known of any mfg to replace an amp because of complete...
17
If you haven't located the short...reconnecting everything can go the wrong way at the worst time...
26
Jeb
Jeb
AR
Gods_Prototype
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
