Hook-up 3 Amp's To Factory Radio
THIRSTYCREW
I need some help with this, so I want to install 3 amp's to an factory radio....(1)will be a 4ch for 6.5 front and rear door speaker's (2) will be for a pair of 8" in the rear deck (3) will be for a single sub in the trunk...but what would I need to send the signal from the radio to the amp's and no i can't change the radio it was to be the factoy one
wat you need is a line level convertor. i've seen them as big as 4 channels but for more then that you'll need either a crossover or a more expensive piece. but the good thing with the more expensive piece is it could also help your sound via a crossover or eq. wat kinda car is this?
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
THIRSTYCREW
THIRSTYCREW
CHICAGO,IL
pentavolvo
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
