Hooked up sub and amp for first time..wired wrong? VIDEO
Bobby322
TX
I just got my new system in (in sig) and I just wanted to hook it up real quick for the hell of it and to see if it even works lol. I want to wire it down to 1 ohm, and I guess I did it wrong but I followed a diagram so i dunno. There isn't like any bass, im guessing from the missing dust cap? Still waiting on it from treo..been a week //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif Anyways, heres the vid:
(its with my phone and kinda shitty, sorry)
lol wheres the large ported enclosure
What vc is it
getting built by vitveet at the moment lol. I do have a small crappy sealed pre fab box that I have laying around that I may use for the time being //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
its D2
Most of the bass is coming from my door speakers
I think you wired it to 4 ohm (series.) Parallel will drop it to 1 ohm. Pos of VC 1 to pos of VC 2 and connect to amp. Do that with the neg and bam 1 ohm. BTW it will play fine without the dustcap.
when me and my friend first hooked up my CVX sub box i had him just connect my speaker wire to the terminals on the box, i said "i have the white wire as positive and the green wire as negative" on the box, he wired the pos from the amp to the neg on the box and the neg from the amp to the pos on the box, while the subs were wired correctly on the inside
it was like this for 2 months until i saw it when i moved my box... and it played fine the whole time.
so dont think wiring it backwords did anything
Wiring it backwards only changes the phase...
183
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
531
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
565
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
658
Bobby322
Bobby322
TX
NoPh33rRaCiNg
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
