what does "active" mean?
basically you dont use the crossover, leave settings flat on radio, have an amp on mids and highs seperate, do all your tuning on the amps.
Active = running a component set without a crossover.
Pros: customizable crossover points, increased efficiency, more flexibility, individual time alignment for the woofer and tweeter (assuming your HU has that ability)
Cons: takes more amplification, more complex, endless tuning.
One amp for the sub
One amp for the mids
One amp for the tweets
Not necessarily..
And it means not using the passive X-overs and using some form on electronic X-over to set your own crossover points for each component.
I have been trying to gather a little bit here and there from what you guys are saying, and what i get from it is you dont use the crossover? how does this work? what are the pros and cons of going active?
Dont do it. In my opinion its not worth it unless you are doing SQ competitions. Half the time you will end up with a network so similar to the passive xovers its not worth it.
Advantages include being able to act like a badass and tell people there setups are no goodbecause they arnt active.
well i have never hooked up components so i dont even know how the crossovers work.
If you use the crossovers that came with your comp set---> Passive setup
If you use an electronic crossover (deck, active x-over...)--->Active Setup.
As a beginner just wire up the passive crossovers and enjoy
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
548
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
Ryan1126
Banned
Ryan1126
San Diego
James Bang
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
