How do I brace a roof
Based
Louisiana
My plan is to get a few strips of MDF or plywood and glue them to my roof going side to side and then putting deadener on the roof, and I plan on using either Lord Fusor adhesive or something like that... But how do I clamp the pieces of wood to my roof long enough so that the glue can dry?
...pretty much my only questioin....//content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
The product you mentioned is for repairing and filling plastic and will not glue wood to metal. You'll need construction adhesive and you can hold the stringers in place with braces that go from the floor to the roof.
oh ok thanks a lot man. Construction Adhesive (Liquid Nails) is a lot cheaper than Fusor lol. And yeah I just watched a video from TwistedChild420 and that's how he did it he just had pieces of wood going from the floor to the roof.
I imagined a sedan with like 2 12's.
I wouldn't use wood unless it's like 2x4 size but that's super bulky, I'd go with flat bar in aluminum or steel (weatherproofed, obviously) at like 2" x 3/8" with round bar welded down the center for a kind of T shape. Welding to the roof would be strongest but would probably f your paint up on the top of your car from the heat. Maybe full coverage with some structural epoxy. That way you still might squeeze the headliner back on.
Assuming this is still a daily driver that you don't want to screw up the interior
PL Premium works very well. I use 1x2's and self tappers into the roof suports to hold the wood in place overnight. Use shims to push wood tight against the roof. Normally easier to do each span in 3-4 pieces since the roof will contour....
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
idk what you have for a vehicle but in my tiny ass chevy prizm the roof took 13 cans of sprayfoam cause there was a 2” gap in the center i have...
6
Based
Based
Louisiana
mlstrass
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
