how do i wire a memphis 500d to 2 jlw3 dual 4
  • Thread starter <Memphis amp help>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<Memphis amp help>
Guest
I have a memphis 500d amplifier. it is a mono block amp but has two speaker outputs(wired in paralell inside the amp). I need to know how to wire 2 jlw3's into a two ohm load so i can get the full power out of my amp. The amp is not one ohm capable. Can someone help me?
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
423
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
855
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
843
Guest
Matt
Brendon Jenness
    May 8, 2024
    May 8, 2024
