Power wire, where to buy
I didn't have any issues with it but it's not quite as flexible as say skyhigh 1/0 ofc.
I'm happy enough with it that I'll be ordering more for my delta build 😂
I am going to try and get some samples, see how it compares to the Anchor marine cable I purchased prior. Hell of a price! If it is even AS flexible, $30 less for a 25 ft run, $60 less on dual 2/0 runs. AND, if you order it a little extra, would have enough for a BIG 3 upgrade!
Looks like its some tope grade wiring. id like a bit stiffer wiring for one my trucks for sure. maybe for my 2500 HD I plan on doing by next summer. Deff try some out. Thanks for the recommendation man. ill check it out
Ill deff check some out as well in couple months.
The 2/0 eb flex is roughly the size of 1/0 ofc sold for car audio
The anchor product measures similar. Much of the 1/0 for cars is loosely packed to give it extra flexibility. Here is the Anchor tinned 2/0 versus KnuKonceptz 1/0 flex -in jacket and when stuffed into a ferrule. The blue is Knu, the black is Anchor marine and the ferrules are L-Knu, R-Anchor.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
6
894
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
3K
ikpthegame
ikpthegame
MN
audiobaun
audiobaun
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
