How do you correctly install a satellite radio?
  • 5
Wragold
I've always seen them with the antenna wire hanging through the door jam. That cant be right. What's the correct way to run the the antenna wire a satellite radio? Is that the right way to run the wire? Im installing one tomorrow and thats why I want to know. Any tips? Its the modular stick to the window cigarette lighter one...If that makes sense.
Check the internet for instructions or maybe the manufacturer site
For as long as I've been here I haven't seen satellite radio come up once
so this might not be the crowd to ask, does anyone care to prove me wrong?
no that is the wrong way to do it as the very delicate antenna will be sandwiched across a piece of metal and eventually get severed.
There are a couple of ways to do it correctly....you can either keep the antenna in the vehicle and mount it on the dash or the rear deck, mount it on the trunk lid and run the wire in the any wiring from the trunk lid or you can route it through the firewall preferrably through a factory grommet.....and no there are no reception issues with them being inside the car as long as the antenna can see the sky.
i ran from the back of the unit under the dash to the door.. then there is the seal and i ran it under that all the way up and go the antenna in the middle of my roof no wire visible
Antenna inside the car, and get an FM direct adapter. Don't waste time with the abortion of an FM transmitter that comes in those things. The XMFX1 for XM and FMDA25 for Sirius, both are about $25.
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
767
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
606
Wragold
Wragold
Charlotte, NC
Ferendon
    Jun 1, 2024
    May 31, 2024
